Innovate Motorsports Digital Wideband 02
Larry Macedo
Sanford, FL
I wanted to post this information a few days ago and just recently had a chance to do so. Thank you to all that have Emailed or called regarding this awesome instrument!
Innovate Motorsports LM-1 Kit (MSRP $349)
Features: Worlds Only Fully Digital Design
2 User-Programmable Analog Outputs
Real Time Display and Output
Accurate to .1AFR
Built in 6-Channel Data-Logger
Included PC Software
Includes Bosch 5-Wire Wideband Sensor
Won "Best New Product-Racing and Performance" SEMA 2003
Benefits: 5 times faster response (100ms Vs 500ms Typical)
Self Calibrating (Heater Calibration)
Simple Recalibration (Sensor Variation With Wear, Altitude, ETC.
Analog Designs Usually Are Calibrated To Work With One Sensor Only
Use With Any Programmable Engine Management System (Or External Data-
Loggers)
Can Be Used To Monitor And Tune Carbureted Applications As Well As EFI
Meets Or Exceeds Accuracy Of Even The Most Expensive High-End Systems
Capture AFR And 5 Additional Analog 0-5V Signals for Complete
Analysis. Log Up To 44 Minutes, In Multiple Sessions, 12 Samples/
Second. Use With Your Existing Sensors (TPS/MAP, ETC), With The
Innovate LMA-2 (RPM Convertor), Or With Any Combination.
Display Log Data on X-Y Axis, Rescale, Zoom In, Print, ETC.
Reprogram Fuel Types, Analog Outputs, RPM Convertor, ETC.
Replacement or Additional 02 Sensors only $59
Proven Winner With Industry Recognition
LMA-2 Auxillary Input Cable #2 "RPM Convertor" (MSRP $99)
Features: Embedded Microcontroller
(4) Additional Analog Inputs
6 Foot Cable Length
Benefit: Capture Tach Data From ECU, Ignition Or Inductive Clamps (Optional $20)
Setup Feature "Learns" How Many Cylinders, Wasted Spark, ETC
Connect Existing Or 3rd Party Sensors To Standard Wire Terminals
Extends Harness Reach Beyond Firewall
LM-1 Kit Includes: LM-1 Meter, Power Cable 1, Bosch Sensor, Serial
Cable, 9V Battery, 02 ****/Plug, CD and Manual $349
Optional Components:
RPM Convertor: $99
Inductive Clamp: $20
Exhaust Clamp: $75
Aux Output Cable: $8
Power Cable: $12
USB-to-Serial Adapter $29
AC Adapter: $35
Analog Display: $59
Sensor Cable: $20 Included In LM-1 Kit
Cig Lighter Cable: $12 Included
02 ****/Plug Kit: $8 Included
Sensor: $59 Included
Serial Cable: $12 Included
Please feel free to contact us for M2 pricing and availability regarding the above listed components. The prices quoted above are manufacturers suggested retail and are not discounted if purchased through the manufacturer.
L
Larry Macedo
Sanford, FL
Thanks for posting the PIC, Mike! We've sold some of these units since posting due to the fantastic pricing we're extending to people of this forum.
