Intake Question?????
MES
Sarasota, Florida
Why did you cut the wires? It has a little tab that you can pull to disconnect it. Anyway if you have re-attached the wires and you still have the check engine light, you can try resetting the computer. Under the hood there is a fuse box. Pull the fuse labeled PCM & ASD wait 5 min then put back in, should reset it. This is for the 97+ cars.
Fort Lauderdale, Florida.
If your not sure which fuse to disconnect, remove the red (hot) wire off the jump post for 30 minutes. OR, drive the car and the light will reset on it's own after repetitive key cycles. Not a problem.
Regards,
Doug
rharon
