TexasPettey
I've recently started to hear a very intermittent squeal from the rear of my Gen1 engine. It's very difficult to replicate. It's not there on startup. If I run the engine for a while at temp & rev it, I can get it to happen, but it disappears after a short while.
It's definitely at the rear of the motor with a sound similar to a belt squeal. I haven't detected any excessive valve noise, even using a mechanics stethoscope. However a search found one or two instances of lifter failure with similar characteristics. I also thought that it might be a throwout bearing making noise. I've got both stock lifters and a stock clutch on the car. Neither have been replaced since the car was new.
The sound doesn't change when I depress the clutch. It has some small change with RPM, but not much. I'm cautious about driving it much to diagnose, since little problems can get big quick when driven.
Any ideas beyond lifters and throwout bearing as to the cause? Any way to tell if the lifters might be bad? If it is the lifters, can they be replaced without removing the heads?
