Update;
Okay it is plug and play. You just don't have to plug everything back in to play.
Two wire bundles come off the wire harness, a 22 point and a 10 point connector, and plug into the radio.
The iPod adapter has the iPod cable and a 12 point connector end and a 10 point end. Plug the cable and the 12 point into the adapter.
The only things that plug back into the radio are the 22 point connector from the wire harness and the 10 point from the iPod adapter.
It plays.
Then the 10 point that come off thw wire harness gets tucked away and not used.
Just to Type A not to have everything plugged in the first time.
THANK YOU!!!!!!!!!!!!!!!!
I just hooked up the IPod for the RBQ... Had everything hooked up, and I was in my garage scratching my head, as to why it wasnt working..
At one point, it DID work on and off, with everything hooked up. But gauges were going crazy, and the display said SIRUIS, not IPOd.. Once you selected "mode" again and turned off the IPOd. You had to recycle the igniton key, to get the Ipod to play again..
Unplugged the 10pin, from the IPod box as you describe, and it works like a charm.. What would I do without this forum..
thanks again..
