04_Mamba
I saw this a couple of times and wondered if its a worthwhile prurchase.
The 6-speed transmissions found on many sports cars are equipped with the C.A.G.S (Computer Aided Gear Selector) system. This system causes the cars to shift from 1st gear to 4th gear at low RPM.
This simple push in device allows you to eliminate that annoying first-to-fourth shift in those vehicles.
Installation is very simple and will only take 10 - 15 min with the included pictured instructions.
This is a resistor mod. This item will prevent any CEL from appearing after disabling the C.A.G.S solenoid. You will no longer be prevented from shifting into 2nd gear during conservative driving. Note: This device will not prevent the Skip Shift light from illuminating on the console/dashboard. After installation the light can be ignored.
Easily installed in less than 15 min even if you have little or no mechanical experience.
http://cgi.ebay.com/ebaymotors/93-05-Dodge-Viper-CAGS-Skip-Shift-Eliminator_W0QQcmdZViewItemQQcategoryZ33736QQitemZ8040083915QQrdZ1
