Well, I got my damper off. I originally had the Paxton Crank Pin kit on my damper.
Since I took off the paxton kit and made my own set up, I decided to do
the ATI damper upgrade. Boy was I lucky!! I was near to spinning my crank!
The paxton pins had appearently broke or sheared off and what saved the hub from
spinning was the fact that I put the pins at a slight angle which cause the
pins to come out of the side of the crank snub which held the crank damper in place!
The casting on the stock damper for higher HP application is not
good! Very cheap and brittle.
If you are doing SC set up, I would recommnend having Doug Levin Key your
system or going the Sean Roe set up on the crank pin tool he has. Way stronger
and better design. It's way more superior than the paxton unit is and for $50 bucks
or whatever the cost is, it's well worth it. Just and FYI.
I got lucky, my damper didn't spin in me...
Cheap Casting Material!
Pins sheared off!
See the dimple in the crank hub?...that pin that protruded the snout...saved me...PHEW!!
Pins sheared off!
