Kennys Viper progress?
Status
Not open for further replies.
Flash Gordon
Motown, NJ
Very well said, Scott. I suspect Kenny's issues reach far deeper than his Viper debacle. In any case, all forums seem to have their clowns and this clown burned his bridges and lost all credibility a loooong time ago.
SRK...Post-on...Oh VCA court jester... :bonker:
Jack B
NE Ohio
City Snake:
I am as tired of hearing about this issue as you are. I am not taking sides and obviously Kenny has a hard time explaining himself. Think about it this way, if you had not seen any previous post and it was succinctly stated that 28K was spent on modifications and the car came back five quarts shy of full (antifreeze). What are your thoughts now.
One last thought, I would think this is more than likely a leak, how could Larry have tuned it running hot?
dyeguy
Gilbert, Arizona
Is there a chance the antifreeze is going into the engine? Hope not but happened to me when the head gasket went out. That's a lot of antifreeze to be missing.
BigsViper
West Texas, USA
Rut Roh! You've done it now! Here comes another 20 pages... :laugh:
Tom F&L GoR
Wappingers Falls
As has been talked about many times here, burping is almost an art. If you don't do it properly, every quart you put in is just going to be pushed right back out when the (still) trapped air bubble expands. No heat? (ding, ding) Rings a bell.
It's an easy fix but example of how much mental thrashing is done when tuning a car by forum.
SUN RA KAT
Guest
The oil looks like just oil thankfully - that was one of the first things I checked.
Put a couple more ounces of anti-freeze/distilled water in last night. I will drive it when I get home from teaching school today. It looks like I'm close to getting all the air out. I will keep burping it until no more air is burped. The floor under the Viper still looks clean and dry.
CitySnake
Manhattan, USA
City Snake:
Somehow, regardless of my thoughts, I'm comfortably certain I wouldn't allow them to propagate into 800+ posts on an internet forum.
My comments are based solely of the chosen method of protest...not necessarily the protest itself.
SUN RA KAT
Guest
:hitfan:
I pulled a sparkplug to see how they looked and it was the same reach as the original spark plugs. I heard that the Jeff Morys Striker cylinder heads used hard to find extended reach spark plugs. I called Jeff Morys and found out Larry Macedo had put the wrong spark plugs in my car which is why he couldn't get it tuned right with the VEC2 and has my car not running right after having it back for 5 months to get it to run right. I pulled some more sparkplugs and they were all the wrong kind of sparkplugs! :evilmad:
Larry Macedo put in Autolite 3922 sparkplugs and the Striker heads require NGK LFR 7AIX sparkplugs.
Joseph Dell
Atlanta, GA 30338
Spark-plugs for JM Heads
I'm coming out of retirement to respond to _this_ post!
There are basically 3 spark plug choices out there for the JM heads. Since the heads relocate the spark plug placement, the plugs actually have a 1” reach vs. the usual plug with a ¾” reach. or in mm, a 25mm or 26.4mm plug will work.
Here are the plug choices:
For N/A cars (or for throw-away-tuning): the champion RC10YC4 plug. These are about $1.30 each. 1 heat-range colder than stock. They run GREAT. I liked them when doing basic tuning and even a little boost.
For SC cars: NGK LFR 7AIX - 2 ranges colder than stock. Around $7 each
For TT cars: The DENSO IKH27 or even the IKH24 for around $12 each. NGK has some plugs as well that are around $35 each, but that's $350/set for 1 set on a viper... does it pay for dinner and rub your back too? gheesh...
For you, the NGK will be a perfect plug. I tried that in my TT, though, and it was a little too hot a plug. The 27 is a good heat range for a TT (which needs a colder plug due to higher pressures in the chamber).
To buy spark plugs, the best price around is usually www.rockauto.com or sparkplugs.com . you can also call sparkplugs.com on the phone, place and order, and tell them you have a company. if you make up a company name they don’t actually check or anything but they will give you 20% off or more on your plugs. That is actually pretty significant when you buy 20 $12/ea plugs.
So go change those plugs, get the car COMPLETELY re-tuned, and then let’s hear about it in a NEW thread!
Joseph
SUN RA KAT
Guest
The Autolite 3922 does not have enough reach to have the spark be in the combustion chamber!
Yes, they are extremely wrong plugs!
SUN RA KAT
Guest
Re: Spark-plugs for JM Heads
Joseph
Thank you for coming out of retirement, Joseph. :2tu:
Jeffy Morys is sending me a set of the NGK LFR 7AIX on Monday. :2tu:
My Viper seems to have the only major problem being tuned to run correctly that Jeff Morys has heard about using his Striker heads.
I plan on having everything inspected on my car since so many "small" things have been found to still not be right, and if Larry did not do the small things right, what about the big things?. I still have to add a small amount of distilled water/anti-freeze after each time I drive it and burp it when it cools down. The Chrysler engineers that did the Gen. IV Viper engine said anyone making the power I am making should have stronger than stock connecting rods put in and I didn't see any connecting rods on Larry's Invoice. And there's a lot more small things - some that weren't a problem until it came back from Larry's 5 month try at making his work on my Viper right that need to be addressed.
G
grcforce327
Guest
City Snake:
I agree with Jack 100%.This is just totally unbelievable!!!For 28k ,the car should have arrived without one single issue, period!!!
Guy C.
Earl_H
MI
I've keep up with this story from the beginning and I am still trying to figure out what you bought for $28k, especially since you already had the power adder and I believe most of the bolt-ons.
KepRght
CA (925)
JD your the man thank you for the plug post. i should have a set of those heads on my car in the next couple months, details like this make all the difference in the world. :2tu:
SUN RA KAT
Guest
Larry has not rsponded to tell me what he did while he had my Viper for 5 months on his second chance - September 8, 2006 to February 1, 2007 - so what he did for $28,000 on his first chance - November 14, 2005 to July 1, 2006 - is what is listed below. Not listed is the 500 mile break in he had me do for him plus an oil and filter change at 200 miles. This was charged to me for $500 as part of the Roe VEC2 tuning that was never performed properly. I'm still waiting for the $500 check that Larry promised to send me on August 10, 2006.
SUN RA KAT
Guest
A couple of months ago while Larry was working on my Viper on his second chance to make his work on my Viper be right my lawyer tried to call Larry and Scott picked up the phone and said Larry was unavailable to come to the phone. My Lawyer asked Scott about my Viper and Scott said he did not recall my car being there.
Looky-see below for photos of Scott working on my Viper and notice what he is holding in his hands.
Camfab
SoCal
Any other shop would charge every bit as much. Complete motor rebuild with Stiker heads, rollcage, halfshafts and the list goes on. Way more than I could afford, but hey, those of you that think performance mods don't come without a price haven't played the game. "Price" = $ and problems
George Murray
Norfolk, VA, USA
Saturn, eh?
Sun Ra's abductors/hosts/longtime male companions must be the same star peeps who grabbed Bugeater and revealed to him that his home planet is Uranus.
You ain't brown-cappin'...that's just Bug coming out for a morning stroll.
Bugeater
Virginia Beach
Congratulations Kenny - your famous. Now please just move to the bahamas. I heard its relaxing there and not too cold. Your battery should be OK. Maybe you could hang out with that other crazy famous person from Texas?
SUN RA KAT
Guest
The Jeff Morys Striker heads takes an extended length spark plug.
These photos show the difference between the extremely wrong spark plugs that Larry Macedo put on my Viper and the brand new extremely right spark plugs that should have been put on.
SUN RA KAT
Guest
Those photos are taken with the spark plugs on a place mat on the eating bar.
It does make a very nice background which is why I used it.
:needpics:
That's why I posted pics! :2tu:
Bugeater
Virginia Beach
Another piece of advice - spend less time importing pictures of spark plugs to the internet, and maybe more time on an elliptical machine. That way you can spend maybe another 12-18 months alive looking at the outside of your GTS before you have a senseless and completely avoidable stroke.
Its a car Kenny. Let it go.
Larry Macedo
Sanford, FL
Holy Hannah! I didn't use the spark plug recommended by the manufacturer and still produced 766/748rwhp and 848/832rwtq. Good Night! That means had I used the spark plug recommended by the manufacturer, we would have shattered the world record for a Roe that we already established... Arghhh! The irony of it all!
We originally used the VEC2 and Iridium plug, but surpassed those dyno numbers with the AEM and the plugs we chose.
Status
tractor1996
