V10SpeedLuvr
I screwed up last night and hit 2nd instead of 4th at WOT so I want to get everything checked out. I'm having a leakdown and compression test done tomorrow. I'm not sure if I hit the rev limiter or not. The car still pulled hard and went into all the gears fine, plus the rearend wasn't making any wierd noises, but I still want to get it checked out to be sure. The guy doing it isn't a Viper tech, but has done lots of work for me in the past and is a real good technician. Is there anything special I need to tell him to do? I know you pull the fuel pump relay and do the compression test at WOT, but are there any other special instructions?
