looking for 96 GTS fuel pump only
lxadeuce
League City, Texas
I've been having some issues with the viper for a while now and it finally dawned on my to check the fuel pressure. I am getting 42 psi at idle and about 18 psi at WOT. the filter has been changed less than 3000 miles ago and even immediatle after changing, the problem was still there. this leads me to believe it's the fuel pump. I have read that the whole module is over $400 and i don't need all of that, I'm only looking for the pump if anyone has one to sell or knows where to get just the pump.
tlcobra
Mchenry Il.
I got a wilburo 255gpm and fit it in the stock assembly. If your handy you can make it work.
MTGTS
Orlando, Fl
You cannot buy a direct replacement pump by itself, I've tried. I called Walbro directly and they will only sell that pump to Chrysler/Dodge. Problem is that there are only a couple of complete OEM assemblies available which are around $700 IIRC. When those are gone (VPA said only 2 in the entire system) I'm not sure what the options will be. The Walbro 255's are not direct replacements and take modification to work. That is fine for the TT and SC folks you prob have an aftermarket hanger anyways but for the stock or NA guy it's not really the way to go.
tlcobra
Mchenry Il.
It was back in 09. Had to cut some of the mount. I got the pump from injected performance in lexinton ky
hyph
I have a pump $300 shipped. Shoot me a PM.
FrankBarba
Maybe it is gold. Especially if there are only a few left. Black Snake... I never asked for your opinion.
FrankBarba
Sounded like a great joke. I guess you bombed in your previous employment.
alwayscode390
STL
What Walbro 255lph fuel pump is the right one for us?
They make MANY model numbers ... thanks :) ---
FrankBarba
Now there ya go again BlackSnake from VA....Please let me know where in my post i stated that i had a used
OEM Fuel Pump? Continue to keep your opinions to yourself since you really dont have a clue of what your talking about.
That's the problem....You speak your opinion before you have all the facts....Let it go. Infact i might just have a stock pile of
OEM parts that you don't know about.
BlackSnake99
Northern Virginia
Any fuel pump for $600 is an attempt to screw someone.
tractor1996
