Losing some coolant behind front passenger wheel????
D
Da1cop
Fort Wayne, Indiana
Its leaking a clear cool liquid behind the front tire this doesnt appear to be the same area as in the pictures......The pictures show the front of the wheel not the rear.
AZTVR
Chandler AZ
... behind front passenger wheel
Oops, I didn't pick up on that fact. :bonker: Behind the front wheel well is the heater which would have cool coolant in it if the heater valve is shut off, I think, but not clear, assuming you have a normal antifreeze mix. The only other thing I could think of is condensation from the AC lines, if you had AC on and high humidity. I don't know if the external lines behind the right front wheel get that cold to get frost or condensation on them.
Viper Wizard
South Salem, NY USA
Darrick,
If it is coolant coming out of the drain of the heater box, it could be a heater core leaking?
Not sure you want to do what Tony says, but if it is sweet that's anti-freeze! :p
tractor1996
