Lug Nut Torque
G
ghengishahn
Louisville,KY
Thanks everyone. Before I asked the question, I searched the forums first. I did not want to be redundantly asking a question that had already been answered. I had no success.
Well I googled it just a few minutes ago and the first hit was on this forum. Here is the link:
http://forums.viperclub.org/srt10-srt10-coupe-discussions/602984-need-lug-nut-torque-value.html
Funny. Google works better than the internal search for me.
Mine is an 03. But I would think the year that would be common to all years.
Valentine61
Bradenton, FL
I can't seem to find threads dealing with damage due to over-torquing. Would appreciate inputs here.
Dealer went crazy with impact wrench, I guess... go the car home and checked the torque - only to find removal torque was 142-14 lb.ft. They just serviced the front end and when I asked the tech what he torqued the nuts to he said 75. I told him I'd be re-torquing to 90, but damn, I needed a breaker bar to get them off.
So question is - at what torque is the bolt strain high enough to damage the studs or the rotors? They appear to have been tightened evenly, so not too worried about unequal torque warpage. I luckily checked this the day after I got the car home and didn't run it hard prior to checking the torque. Needless to say, the whole event has me "TORQUED!".
I may revert to my engineering books to try to calculate the answer, but I don't know the grade of steel used for the studs... so the exercise may be worthless.
Thanks for your inputs!
Valentine61
Bradenton, FL
Since I was venting, I think my question got obscured. Here it is again...
At what torque is the bolt strain high enough to damage the studs or the rotors?
vancouver-gts
Vancouver BC
140+
You can't damage the rotors by over torquing the lug nuts but you can ruin/stretch the thread/pitch on the lugs by over torquing.The lugs should be no less than 8 grade just like flywheel bolts.I'd stick with 90 footpounds for the street and periodically check after spirited driving.Should check them once a month at least.
uvbnbit
Kingston Springs, TN
I see it all the time. Idiots at these national chain tire shops think they are in a pit area changing as fast as they can at 130+ lb ft for everything. Typical passenger cars can be as low as 65 lb feet. I actually had a stud shear off trying to loosen it 2 days ago. Guess who got stuck paying for it. You guessed it, $105. Lost money on wheel repair because some F-ing, punk-a$$ kid is too F-ing lazy to look up, set to proper torque spec and use a torque wrench. I don't see how these "well know" shops are not constantly in lawsuits. Who knows, maybe they are?
Phew, now I'M done venting. :D
btw, you can damage the wheels too by overtorque.
-Chip
Valentine61
Bradenton, FL
Mr. Mom
The Milwaukee tool video clip is a hoot! Thanks for sharing...
Keep them Milwaukee tools out of the hands of the service techs working on our Vipers! They're for "professional use only"!
Valentine61
Bradenton, FL
Has anyone ever asked the SRT engineers exactly what the material spec is on stock lugs? Specifically the Sy (yield strength) and Sut (ultimate tensile strength) or Sp (proof strength)? I'll try to find out then do some fancy engineering calcs to try and determine at what torque damage is actually done to lugs by exceeding their strength... assuming damage isn't done by warping rotors first... Looks like lugs are 1/2"-20, but can't determine if they are Grade 8 as suggested by someone... If they are, the Sp should be about 120kpsi.
FirecatF7
