I was wondering what would be the maximum compression ratio on 93 octane fuel before you need to start using racing fule?
I have an N/A motor with a 10.66 CR and wanted to increase the CR to around 12:1 CR.
What year car and engine and how many miles on it? Depending on cylinder head material, spark plug heat range and location, timing, etc., you're right about at the limit at 11:1 with 93 octane (maybe a bit over the limit after you get some carbon build up). With 12:1, you'll definitely need to blend in race gas. Or, you could look at water injection. If done right, it can help a lot with detoonation and keeps your cylinder heads nice and clean.
It's an 02' GTS with only 6K miles on it. I just did the motor 500 miles ago with new C&C ported heads, cam, lifters, R&R rockers, and a split second computor. Also, would I need to change the injectors if I increase the compression?
700rwhp is not going to happen NA on pump gas easily, possibly at all. You'll need the largest ci bottom end with Striker Race heads with further portwork and a custom intake. The cam will have to have a lot of overlap. So much so that it would make the car no fun to drive on the street. I think that if you remove the pump gas limitation then you can meet your hp goals with a better driving combo.
Either way good luck and keep us posted on your results.
Martin that sounds like a wicked combo. A few questions if you don't mind me asking.....
What Gen is your motor?
If Gen II, did you go with bigger throttle bodies?
Did you maintain the stock fuel system architecture? Bigger pump and enlarged stock injectors or complete retrofit?
Bored and stroked? If stroked did you off set grind or go with a complete new crank.
Cam duration @ .050 and LCA?
What size and who's header?
If you don't want to disclose the info. I understand, and or if you prefer you can PM me
Nope, kept the piston and rods stock. I figure to have some fun with it now and eventually work myself into a stroker. Maybe a 510 or 522 stroker.
Where can I get more information about stroker crankshafts? I have a (loose) crank that might be one, but I'd want to measure the throws to know for sure.its gonna be a stroker sooner than later with those cast pistons and a higher CR i bet....lol
Martin, sounds like a great setup. Do you have any dyno sheets that you would be willing to share? I'd love to see the power curve.
JD - Email is a problem here at the beach..
Neptune's Retreat is my beach house - 10% off for any viper owners!!
l8r - MD
