Misfire ?? Help Needed
M
madbrian
a vacume leak nor a map sensor will cause this bucking treatment,your running up the wrong tree.
are you sure a vacuum leak will not cause severe bucking?
if this is the case the next job is to check the fuel pump.
please can anyone tell me what i will need and where to connect it etc?
thanks
Fatboy 18
Surrey, United Kingdom
I will ask around, if anybody knows of a good garage / tuner for you. Now which bit of wales are you in North? South? Cardiff area? Swansea? Will help with locating a garage :)
Theres a couple of UK members in Wales :)
Toby52
