What does DC use to reflash the PCM? Can he adjust the fuel trims and the timing? The VEC2 can only adjust the fuel. What other options are there for controlling the timing and the fuel trims other then an AEM?
HPTUNERS apprently are working on a package for the Viper, similar to their LSX software. This is what they told me at the SEMA show.
I thought the VEC2 was able to advance the timing also ...
We have our own set up to reflash the pcm . Yes we can adjust the fuel trims and timing .
The AEM is a stand alone pcm . Other options include Perfect Power (can only remove timing) , Dastek Unichip (unreliable for srt's) , and split second (can only remove timing) , VEC2 (timing and fuel - best piggy back out there for the viper) , APEXi safc , etc . I don't recommend any piggyback fuel control on the 04 and up SRT vehicles due to the fueling strategies these cars have . If you are going for timing control , something like the VEC2 should work well .
- Chris @ DC Performance
Hi Chris, thanks for the response. What does your own setup used to flash the PCM consist of? Is it a DRMII?
