msd or kennybell booster pump
vipzilla
CAPE COD MASS.
ok there are old threads but alot of you now have more experiance wich one should i get for fuel booster pump and why?
speedracervr4
Lancaster, PA
If you decide to go with an MSD unit, I have one I'm not using I could sell you. I upgraded to dual Walbros when I went with the 10lb pulley for my Roe.
Viperless
MN
I used the KB on my supercharged GTS. Worked great. Maintains a constant voltage to the pump at all times.
Viperless
MN
get a real fuel system
Still a nice addition even if you have a "real" fuel system due to the feature mentioned previously. I had a pump capable of feeding 1000 boosted hp but still ran the KB BAP with it.
Dan Cragin
LA, CA
The KB is specified for pulse modulated systems so we use the MSD. Magnuson makes a booster called a Magna-booster that is widely used.
ViperGear
