MICHAEL WILSON
Hello everybody
I was doing some detailing on my 2008 Coupe. I removed both Wheels on the passenger side, I use my pressure washer to remove the built on gunk on my control arms on the front and rear along with any other built on crud that was in the wheel well. I thought I was pretty careful but maybe not.The next day when I drove the car I got a check engine light in the driveway.. I put my engine analyzer on it and read the codes it said that I had a gas cap loose so I re tighten the gas cap and cleared the codes out. The engine light has not come back on but I still have several codes that are active. I replaced the gas cap and removed the shields underneath the car and examined the canister and Associated equipment everything looked okay( also how do you remove that aluminum shielding that covers the charcoal canister? It's soft and ends easily but it would be easier to look at if I can completely remove it even though it is malleable)
The car seems to be running okay it revs up and starts up and runs down the road okay. It feels like it's running a little bit rough, but honestly that could be in my head.. Below is a list of the codes that are coming on when I read the ECU through the OBD2 port... again mike check engine light has not come back on... Any help with this would be greatly appreciated.
Current Fault Log
P0455: Evaporative Emission Control System Leak Detected (gross leak, check fuel cap, piping etc)
P1628: [Chrysler] ECT Pull-Up Resistor
P2104: Throttle Actuator Control System - Forced Idle
P210E: Unknown code - More information may be available on the web
P2127: Throttle/Pedal Position Sensor/Switch E Circuit Low Input
Pending Fault Log
P0457: Evaporative Emission Control System Leak Detected (fuel cap loose/off)
Current Fault Log
Pending Fault Log
