viperbilliam
Eight months to do a motor?!
Very doubtful that they would help, I asked them last year if they would build me a motor.
They basically said they only do the whole thing.
I wanted to be apart of the build, so that didn't work for me.
They still do some nice work on there cars, just way to secretive.
Lets add more fuel to the camp fire!
Spacers required for the oil cap to clear the TD rockers by "House of Billet/Fast-Hemis.com".
(BTW...for the people that are purchasing TD rockers newer than 2004...do not worry TD fixed this problem a long time ago...BUT LPE had no clue as expected...)
Here is the short version.
Ordered / Prepaid / asked for Overnight Delivery when finished machined.
After (give or take a few days) 2 weeks of our stated delivery day they finally showed!
One of the the spacers look as if it was used a learning mistake.
The o-ring material sent with them was short on one side.
The surfaces were not even close to being flat.
The rear upper bolts can not be tightened unless the cowl is removed. LOL
The studs they shipped were surfaced on a lathe on one side but bolt cutters were used for the other side...along with having 6 different lengths.
In this economy you should not even think about sending something out your door like this...but their excuse? "Well you were in a rush".
To make matters worse....The patch harness we purchased had the VSS wring not correct. I will refrain from "rat'n" on this person since he did help when I called him each time...which was 5-6 times a day for the last week and a half...For the last week I have been testing every component to make sure its only a wiring issue and not a hardware problem... me "HEY MAN, YOUR WIRE HARNESS IS NOT WORKING" him "ARE YOU SURE THE ABS/ECU/DASH IS NOT THE PROBLEM?"
The ABS module checked out fine today as did the dash cluster and the ECU... what a pain in the ass this was without the Dodge DRBIII scan tool... Stupid Snap On Modis did the trick though....
Stuff like this can get people upset quickly, especially when the car is together and you have to take it apart 3 or 4 times to make sure we did not cause the issue.
Once I correct the errors we found with the harness I will be heading back to the dyno to finish this thing up.
Howard
PS... please do not take any offense with my sarcasm... This is as diplomatic as I can be... If I had it my way my words would not be so kind.![]()
Yea...It comes up much faster if I just stabbed the throttle but it breaks the tires loose on the dyno 3 out of 5 times I do it, so the torque curve is a little shy of what it actually does down low since I am "rolling" on the throttle.
I sent Aries his plot vs a Stock SRT-10 with the identical Paxton setup we tuned on a VEC3 awhile back... The midrange of Aries setup is incredible.
Howard
is it me or does that torque seem to be falling off a lot faster now ?
power under the curve looks nice though
