I agree with Greg. Does the alarm work? There is a Schraider valve on the intake manifold that when the cap is released has what looks like a tire valve stem. Protect your eyes and see if there's fuel pressure when you depress the stem gas should spray out indicating fuel pressure.
Check all fuses and switch out the ASD/Auto Shut Down Relay in the PCM/Power Control Module. Change headlight and ASD relays to check. Fuel pump fuse and relay are in the trunk on driver's side.
Not sure which fuses could be the problems with your (97?) but my 01 had a blown "guages" fuse and the engine wouldn't start.
