My GTS Passenger Window Went Dead
Hisserman
Waterford, MI
The switch for my passenger window went dead today. The speakers and door locks still work in the passenger door. Anyone have any ideas? Is it a broken wire in the bundle that is hinged through the door? Anyone have good ideas for diagnostics? I searched for previous posts, but came up dry. Thanks. :rolleyes:
Qualitywires.com
Louisville, KY
it's probobly your window switch. Mine went out and I got it replaced under warranty. It's the two switches on your console
Fast Viper Dan
Saratoga, CA, USA
Could vary well be the wire harness. You can pull the bezel off the dash and the switches are right there. Then use a jumper wire or test light to check for power going in and out of the switch. The Bezel comes off the American way, Force it! It's held on with spring clips. Get your fingers under one side and start working your way around pulling out a little here and a little there and before you know it, it's off!
If your car is still under warrantee, I would take it in. If it is the harness it might be more than you want to deal with.
Good Luck!
Dan
:2tu:
GTS Bruce
Orchard Park,NY,USA
Try the switch first.Dodge toggle switches are well,sort of crappy,Often can be rehabed when carefuly taken apart and put back together.Cleaning up contacts etc. Bruce
H
Hisserman
Waterford, MI
Thanks guys. I'll check out the switch and if nothing there, head for the dealer. It's still under warranty.
tractor1996
