My PS2's Tires Needed Balancing
RevHeat
San Antonio, Texas
Just wanted to post an FYI. During the Texas Viper Roundup, I noticed that my front wheels seemed out of balance. Well I finally inspected them today, I found out that I had lost all the weights on both tires. For now on, I am going to monitor the weights to make sure that they are still there. I have no noted on many weights should be on each rim.
Rev
99 R/T 10
Enterprise, AL USA
After you get them balanced, it would be a good idea to cover the weights with silver duct tape. They should not come off again, at least not until you're ready for them to come off.......................:D
pdmracing
Atlanta Ga
use the foil/ air conditioning duct tape. Use a lil laquer thinner to clean & it will stay forever
Jack B
NE Ohio
Duct tape stays there forever - in my case anyhow. You should also be using adhesive type weights, not, the hammer-on units. With the adhesive types you can usually get them out of harms way.
