need advice on the fuel assembly...
Qualitywires.com
Louisville, KY
I got access to the fuel assembly in the rear under the cover. How do you pull the pump out? It looks like there is a ring that suppose to turn?
I don't want to force anything so any advice how to take it out?
Thanks!
Joel
Ireland
Unscrew the ring in the normal way, it will be tight. Disconnect the pipes first, then lift out the module.
Q
Qualitywires.com
Louisville, KY
Thanks,
I had to use a hammer and a piece of wood. That thing is on tight!
I got the assembly out and now I am working on the fuel lines.
