JST2CRZY
My 96 GTS w/ roe sc is showing service engine light #505 (idle control system malfunction) I pulled the idle sensor apart to check for dirt or moisture. It was clean. Is there any way to check the sensor to see if it is good?
The idle is erratic at times. It will fluctuate between 200-1000 rpm,and at times it will stall when coming to a stop. Any ideas? Thanks, Bill
