Need Dodge part # for 180 degree thermostat and......
Edward 96GTS
Monterey, CA
spark plugs and
tranny fluid to take care of NGR.
brake fluid
fan upgrade "connector"(new fan has different connector plug)
TIA
tommygun
T-STAT P4876900
PLUGS SP0RC12LYC
COOLING FAN CONNECTOR 5014007AA
TRANS FLUID, WE RECOMMEND AMSOIL.
BRAKE FLUID DOT4 4549625AB.
HOPE THIS HELPS.
venomblue550
tommy, the tranny fluid, what kind?? ATF??, and in order to change to 180 thermostat, what gaskets do i have to change, and the part #???
Janni
Raleigh, NC, USA
Edward,
The new fan was a drop in replacement on both our 1996's are you sure you need the different connector?
The Year Matters. No connector needed.
T-stat is probably a waste of money and especially time.
BURP the car thouroughy, upgrade the puny OEM 96.5-98.7 fan. Done in 1 hr. Wash the radiator fins, look wide in the facia. Drive happy
tommygun
Does the intake manifold need to come off in order to change the thermostat?
No the manifold does not need to come off to replace, but the cowl does.
part # for gasket to block #5245643/requires 2.
part # for t-stat gasket #4763839.
Chrysler recommends dexron IIe or dexron III for transmission fluid change but a tag on the side of the transmission should have the actual # for Castrol Syntorq which is a synthetic transmission fluid. Chrysler's parts catalogs do not list the part # for this Castrol, but the # on the trans is available through Mopar parts and has an Amsoil equivalent.
If and when you replace the t-stat, make sure to replace the hose clamps on the housing and you may thinka about replacing the hoses at the same time. Sean Roe makes a very nice set of silicone hoses that fit beautifully and come in a couple different colors and have a bleeder screw built into the upper radiator hose that makes bleeding air easier/good luck.
venomblue550
i talked to chuck and my local dodge dealer, they told me the T-stat job is about 1.3 hours, and intake manifold will have to come off?????? so how do you do it without remove the manifold???
WESTCOAST JASON
Temecula, CA
The intake manifold on a Gen2 does have to come off to change the T-stat. A 180 thermostat can be very helpful in keeping the engine cooler and going to the updated fan is a great mod for any earlier Gen2.
tractor1996
