need help with speedo recalibrating
SNKBYT
E.SWANZEY, NH
I am looking for the dip switch settings for recalibrating to a 3.45 rear end. The dip switch was installed in 1997. Does any have the sequence for this ratio? Thanks Tim
Motor City Mad Man
Las Vegas, NV
SNKBYT, check out this link to SPECMO's website. SPECMO they have a link on there for dipswitch settings. I believe I have a 3.45 axle ratio also and the switch settings were for a ratio of .8929? , the link should be cut and 5, 6, and 7 dip switches should be in the on position. At least that's the way I read this. My SPECMO RB-2120 speedometer recalibrator melted inside the engine compartment from the heat and I replaced it with one from Sean Roe that goes inside the car.
