Tom F&L GoR
Within the span of two city blocks, I started to hear a loud chirping noise. At first I thought it was something rubbing on a wheel or wheel bearing, but at the next stoplight it didn't go away. By the following light it was easily loud enough for me to hear all the time over the 3" exhaust. I pulled into a parking lot and the chirp was so loud and had a sharp "ring" that I couldn't tell where it came from; front half and inside the block is all I could guess.
Got home, released tensioner and loosened the serpentine belt - noise still there. It's related to engine speed, although a low frequency, like maybe cam speed or rocker arm? It seems to sound the same from standing on either side of the engine, no difference when removing oil fill cap or breather hose to listen, the volume doesn't change with engine speed. It hasn't gotten louder (60 seconds to begin, but after 10 minutes to get home, it's not worse.) If you were deaf, you wouldn't notice anything different. Oil pressure, oil temp, coolant temp are normal. No unusual smell.
I suspect something is rubbing, but it sounds like steel on steel with no oil. There aren't that many places where something steel can rub on something steel, though. Maybe a timing gear is rubbing? Any Gen 3 experience?
The only thing I can compare it to is when I had a rebuilt 318 and they put in a rocker arm shaft upside down. The oiling holes sprayed oil in the rocker cover rather than between the shaft and the rocker arms, so it started squeeking pretty quick. But this noise is much louder and sharper.
~73,000 mile Gen 1, lots of use, little abuse, good maintenance. Any ideas?
