Barrels
I am doing a plugwire install and starting to remove the intake manifold. I cannot get the bolts that hold down the manifold to turn. I think I am supposed to be using a 3/16 hex key. That seemed like a better fit than everything else I tried. So here are the options I can think of:
1. Use a stronger hex key (currently using standard Craftsman)
2. Use a different size key
3. Spray with WD-40 and try again
4. Spray bolts with Aerokroil and soak overnight
Can someone who has done this before give me some tips, or let me know which of the above routes would work best? I'm stuck until I figure this out, so quick advice is doubly appreciated.
