New Twin Turbo system from West Coast Viper
britospeed
Jason, any updates on the TT? What HP & TQ did you get out of it?
P.S. it looks great!!
dansauto
gillett, pa, usa
yes, yes how is it coming. You know those gen1's will produce a ton of torque. I would not be suprised if it is over 1000 ft lbs!!!
SingleMalt
Looks cool, but with all of that exhaust tubing in the engine compartment, isn't heat soak going to be a complete *****?
W
WESTCOAST JASON
Temecula, CA
No numbers yet, the turbos were sent out to have the purple inside case marking changed to red. (a customer preference after he saw them purple) We just got them back and are starting the in-car install!
The heat soak from having the turbos down where they were on my car originally was actually the problem. The location of the turbos on the new system allows for air to pull the heat right across the compressor housings all the time. Additionally, the turbos are ******** coated with a ceramic coating that keeps the heat in. (helps spooling big time too!) A number of people have asked about that heat issue, including one recently, that was the first to ask about the heat affecting the serpentine belt. (that was brought up in our internal feasibility meetings, but this was the first time a VCA'er asked that one) All these items were addressed by the contracted engineer on this design and we got the green light! We will have the car on the dyno and being tuned soon and complete and detailed performance specs will be posted in this thread. Kit form instructions are being authored also. Thanks to all for the interest!
SingleMalt
Sounds like a winner, Jason :) Can't wait to see it!
Mike
Alternative
It was the first thing that came to my mind when I saw the design, so I had to ask when I spoke to you. Good luck racing this weekend...
P.S. I hope you didn't me bugging you again today, thanks for answering my nitrous questions.
W
WESTCOAST JASON
Temecula, CA
details, details, details. The intake manifold is at the custom paint shop. It is getting the smoothie treatment like Foose did on one of his projects.... I am VERY ready for it to be back!
W
WESTCOAST JASON
Temecula, CA
:2tu: Sorry for all the delays in responding. We have been very busy. (so much that we can't even get down to VOI this year. No customer wants to hear we are stopping work to go to Texas) Here are the pics of the kit on the car. Intake should be installed next week and fuel system is done. Dyno numbers coming right after. Then finally, pricing. Thanks for all the interest.
-Jason
Catwood
from the WCV website
Two ITS T03/T04 Dual-Ceramic Ball Bearing Turbos rated @ 550HP each
(Turbos are cooled by engine coolant – lubricated with engine oil)
Adjustable from 7-15 PSI - inlet temperature only 50 over ambient
Two HKS Sequential blow off valves (adjustable rate and tension)
Two Turbonetics wastegates w/multiple spring sets and boost adjust ports
Two mid pipe connectors (adapts to factory tubular headers)
Two custom side sill pipes with resonators and cat delete
SplitSec FTC-02 (fuel & timing computer w/laptop interface) & Harness’s
MSD Viper Boost Retard box w/ in car dial (adjust on the fly for bad gas, weather)
In tank 255lph upgraded feeder pump
Barry Grant King Sumo 2000HP Fuel pump
CPR billet Regulator w/return and 1:1 boost reference
10 (ten) CPR 42 pound high rate fuel-injectors
Two custom billet fuel rails
Two 02 eliminators (replaces factory 02 sensors in rear bank)
Custom front mount intercooler w/top balance tank (81” Charge Area)
Two K&N Conical Air filters with a mod plate for aid in airflow
Two Custom oil pans for Turbos w/oil plumbing lines and internal baffles
Two electric oil pumps for Turbos w/lines for oil return and wiring/relay package
Modified passenger side valve cover for oil return lines
Fuel tank pickup modifications and return line outlets
Full braided fuel system lines with A/N fittings throughout
Complete plumbing for vacuum / boost regulation w/manual boost controller
Complete stainless steel piping for fresh and pressurized air
Autometer boost gauge with column mount
Autometer fuel pressure gauge with cowling mount
Flowmaster dual chamber mufflers in factory position
All other braided lines, couplings, harness & relay sets, etc. included
FTC Tuning software (R4 controller)
GEN2 forged motor will make 700WHP on 91 octane fuel.
1 year unlimited mileage warranty.
Regular price: $29,995.00Sale price: $25,000.00
dansauto
gillett, pa, usa
That is not the same system West Coast is doing. That is the Axis kit Jason T. used. I believe West Coast's kit is being co-developed by Pro Turbo kits.
dansauto
gillett, pa, usa
That was an installed price 2 years ago. Note these are 03/04 hybred turbos and are not real efficent at the airflow required for those Hp numbers he claimed. The post above is NOT Westo Coast Vipers kit. Thier's was a front mounted kit while the Axis kit above is mounted low and requires pumps to get the oil back to the pan. The West Coast kit also used T60 turbos (much larger than the hybreds on the axis kit)
tractor1996
