Next best mod, VEC1?
Alternative
I'm thinking of getting the Roe Racing VEC1, and would appreciate to hear pros and cons. Also, I'm pretty sure that I'll venture into the forced induction (DLM), or nitrous (BTR) applications (but not for a while), and I'd like to know if the VEC1 is compatible with the packages offered by either tuners.
Thanks!
Bad02ViperGTS
MD
I was told by the local tuner that the Dastek was better and out performs the Vec1. I am sure it comes down to opinion, but my car runs good with it and I am very happy with the power it puts out with no motor work.
Bad02ViperGTS
MD
The cost on a Dastek run around 500 and as far as I know most all vipers tend to run rich at high rpm and the Dastek would help your air fuel mixture which in turn will give you your max hp....
rharon
