I put in NGK Iridium IX plugs today. The numbers for the plug are BKR5EIX and 6341. They were $6.95 a plug. They came with a .028 gap - which I used per the NGK tech's suggestion. The Bosch plugs Sean used in February, 2500 miles ago, were in pretty good shape but I figured that I would try out the Iridium plugs that some of the VCA members are chatting about. Do they give better performance? I do not know except for one specific area of performance. The car was not rough and did not buck for the first mile after cold start up. With the Bosch plugs, the first mile or so was rough until the plugs and engine heated up. I did a few acceleration runs to heat up the engine. The new plugs continued to work. It could have been a fluke but it seemed like there was less popping on decel. The shape of the tip is very different from the Bosch plug. The Bosch is broad like a traditional plug. The Iridium is narrow - almost like a needle. The plugs I used are currently being used as original equipment by Bentley for the Continental Coupe twin turbo engine. Anyone else care to share there observations on Iridium plugs versus some other kind of plug?
