NOS ON A 99 RT
SMCBUILDERSINC
Hilton Head Island, SC
WHATS THE CHANCES OF CATASTROPHIC ENGINE/CAR FAILURE WITH THE NITROUS EXPRESS KIT. JET CHIOCES ARE 50/100/150/200/300. IVE HEARD WITH THE SOLINIODS MOUNTED IN FRONT OF THE THROTTLE BODYS THAT THERES A POTENTIAL RISK FOR THE WHOLE THING TO BLOW UP AND I COULD POSSIBLY LOOSE THE HOOD AND MANIFOLD. IS THIS COMMON. YOU HAVE TO KNOW THAT IM NEW TO THE NOS SCENE. ALSO, DO ANY OF YOU FELLAS KNOW WHERE I CAN GET A SHOP TO DO THE INSTALL?? HOW MUCH? ANY HELP WOULD BE APPRECIATED...
TOOOFST
Barrington,il
Search Nitrous,more questions and answers!If your crazy on the street all the time,I suggest a small supercharger.If you want to give a spanking here and there NOS will do it.Good luck!
The KaBoom Factor=like driving in the rain,be carefull and everything will be ok.
MES
Sarasota, Florida
<HR></BLOCKQUOTE>
Almost 0% but there is always a chance of something going wrong. Most of the failures (general failures not just Vipers) are either melted pistons (too lean A/F) or your piston being blown out the bottom of the engine block upon startup due to a leaking solenoid. That's why you should always de-pressurize your nitrous line after each use and if you run a gasoline fuel enrichment let the car idle 5 minutes after the use of nitrous prior to shutting down, to let any extra fuel laying in the manifold to burn/evaporate off, how's that for one big run on sentence
Tom Welch
Blairsville, Georgia
SMC,
Nitrous, like any other modification is only as good as the quality of components and competence of the user/installer.
My own Viper makes an additional 300 RWHP with nitrous, on the stock bottom end with no ill effects. I race the hell out of my car.
The elimination of Detonation is the key to any good nitrous/supercharge/turbo installation. With correct air/fuel ratios the power potential of any internal combustion engine becomes substantial. The best part of a nitrous application is that any excessive engine strain-wear is only taking place during the short bursts of nitrous injection.
Remember one simple item........YOU GET WHAT YOU PAY FOR.
Good luck with your search.
Tom Http://btrviper.com
1997 BTR 750 SS "PLUS"
800 RWHP
944 RWTQ
10.20 @ 141 mph(single stage only)
tractor1996
