rhallman
- Joined
- Aug 14, 2010
- Posts
- 102
- Reaction score
- 0
Well...changed the oil in my 2005 vert and all went as the past changes went. When installing the filter I normally tighen by hand then with a 1/4 turn with the filter wrench. This filter seemed like it took more turns to get it seated...but didnt think anything of it. Filled up with oil and warmed up the car checking for any leaks. All looks great.
Took the car out on the road and got about two miles and noticed the oil pressure was dropping.....then I smelled oil. Immediatly shut the engine down and coasted to the side. We live on a rural road so not much traffic. Got out and saw a trail of oil down the road and oil leaking out of the engine bay. fortunatly I wasnt to far away from the house, so I walked home and grabbed the truck. Towed the car back to the garage to see what happend.
No leaks on the drain plug and then I looked at the filter. It was still tight. I looked at the old filter and noticed the rubber seal wasnt on the filter. I removed the new filter and noticed right away while removing the filter the rubber seal fell into the oil catch can. There was also a seal still on the filter that I just removed.
Im guessing that when I installed the new filter, the old seal was still stuck up on the engine!
Ordered a few new filters....and now Im off to try and figure out how to clean up the underside of the car of all the oil. Top half looks pretty good...pretty much stayed under the car.
Anyone have an idea what works the best for cleaning up the oil?
Some things that you think are so simple....end in a train wreck!
Rich...
Rich...
