<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by jasontarnutzer:
Now that is an interesting idea! Are those online so I can see a picture of them?
<HR></BLOCKQUOTE>
There are 2 designs - one is a diaphragm or reed valve type and
goes by the brand name Krank-Vent. It looks like a small metal
gas line filter. The other type, which I have used,
is a precision piece of billet aluminum that has a movable, spring-loaded piston inside that acts as a one way valve.
It is about 3" long and 1" diameter, and is fitted with a 3/8" ID ****** for connecting to vent on motor, the other end can
be fitted with a mini-filter. Both types are available thru
aftermarket motorcycle suppliers. All other vent holes on the
motor have to be plugged, so the dipstick/hole would have
to be modified to seal properly. They are advertised to keep
crankcase pressure constant and lowered, helping to rings to
seal better and preventing oil leaks caused by high crankcase pressure.
