I've noticed everyone saying the oil pan drain bolt for the gen 3 SRT10 is removed using a 14mm wrench. I'm changing the oil right now and noticed my drain bolt needs a 16mm and there are no metal shavings on it either... I also noticed my drain bolt has no magnetic properties at all. Do I need to replace the drain bolt with the OEM one? Or will the one that is currently on the car be okay?
