I just replaced the oil pan gasket on a 97. The following are observations and questions:
1. The original oem gasket was a bakelite base with a fairly large rubber bead on both sides.
2. The bad rap on these gaskets is that they supposedly blow out, or the bakelite can crack and cause a bad leak very quickly. I have also heard that some of the pan bolt holes actually are open into the engine interior. I checked mine and all the holes were dead ended and did not enter the engine interior.
3. On the other hand I have pulled the pan at least 5-6 times and reused the old style gasket without a leak. This time the gasket was leaking, but, it was obvious that the rubber bead was damaged. Therefore, the need to buy a new gasket. I believe I made an error on the gasket cost in an earlier post, the new gaskets cost a little less then $200.
4. The new gaskets are a base of aluminum, however, the rubber bead is a fraction of the size of the older gasket. It seems we gave up one problem (blow out) for another possible issue, leaks.
5. I have pulled the pan and recaulked the four seams (in the corners) three time now and I still cannot get it to seal. The characteristic of the leak is that the pan bolts in the back are wet.
6. From what I can tell, it is one of the seams in the back that is leaking. Does anyone have a recommendation for technique or caulk/silicone that will solve this problem.
