Paxton / Split Second Question
GR8_ASP
Anyone ever use the fuel control portion of the Split Second unit? If so I could use some assistance.
The Split Second website has instructions indicating to connect the violet wire to the MAP sensor lead. It also seems to indicate cutting the MAP sensor lead. Sounds straight forward but I want to make sure that is correct as I don't want to do this and find out I made a big boo boo.
The next question is in regards to the fuel map. Can you use the stock fuel map only modifying a few regions by adding or removing injector dwell? That is what I would like to do in general.
BTW AB thanks for helping me figure out how to download the map. Now is the time to start playing with it.
viperkraz
Call Velocity Performance at 9723899877 and ask for Andy or Stoney. They have tuned several SRT10's with the Paxton.
Hope that helps.
BigCarrot
Dallas, TX
Hope that helps.
That's what I was gonna say. They did some tweaking on mine today!
