Porter Cable
slysnake
I can pick up a used porter cable 7424 that is fairly inexpensive. Is the xp so much better I should only accept that?
Bird325
Ft Worth, Tx
I think the only difference with the XP is a slightly higher top RPM. If you've got an excellent deal, then GO for it.
thompsonracing
Chalfont, PA
Tools plus is a good site.
I have two of the older 7424s and they are great. The XP is a step up for sure, with a redesigned grip/switch. I'm not trading mine in!
Hit me up if you need the pads and polishes.
AND REMEMBER TO WATCH THE JUNKMAN VIDEOS BEFORE USING!
thompsonracing
Chalfont, PA
Also, there are very few tools I've ever bought used, simply because you cannot get them anymore. Make sure you know the person you are getting it from.
PCs are cheap enough, I recommend getting a new one. You can get some pretty good packages too!
Make sure it comes with the tool to change the heads.
slysnake
Yeah, I think I'll just go with the new one. They're not that expensive anyway. Thanks for the input everyone.
bmillionaire
