Powder Coating rear calipers?
RalphieViper
Anyone with a Stoptech front brake kit powdercoat the rear calipers to match the front reds?
If so, where?
KepRght
CA (925)
phone book, check with a hot rod shop for a local source.
there are kits you can do in your oven, not recomended.
Anthony - 98 GTS
Houston, Texas
Why didn't I think of that? :smirk:
Anthony - 98 GTS
Houston, Texas
Anthony,
Did you get new caliper slide bolt dust boots? Where did you find them?
Hey Tom,
No, actually after I had them powder coated and tried to install them - the pistons were bad and I ended up using a different set. They did look great. :crazy:
R
RalphieViper
I'm in NYC.
Anthony- nice job! Do i have to take out the piston and seals, or could i just send them out as is?
Ralph
Anthony - 98 GTS
Houston, Texas
I'm in NYC.
Ralph
I did not have any problems. Everything on your brakes are designed for high temps. Most powers are baked on in the 300-400 degree range. Talk to you powder coater and and just stay in the lower temp ranges for the minimum times.
Nocluehow
