Torquemonster
Do you like it tight?
Don't we all.
Well here's how to pick up some serious hp gain without buying anything except labour and machine time - by simply making your engine tight in a key area....
the "quench area"
Actually I lie - you'll need adjustable valvetrain - roller rockers, but you wanted those anyway didn't you?
Assuming stock clearance is over 0.050" if you blue print the quench to around 0.035" you'll pick up more power than just about any popular bolt on goodie. CNC port the heads while the engine is out and compound the effort - just don't lose air speed at low to medium lifts!
With the cast pistons you can get the quench very tight as it has tighter bore clearances than the forged piston engines - which could still handle 0.035 piston to head clearance @ TDC - but that would be about the limit for them unless someone has found they can go tighter. The cast piston could possibly go under 0.030" but I'd not be game to be first. - I've seen 0.027" to 5500rpm before touching on a straight six. I'd go to 0.030" on cast pistons max - but 0.035" is safer for most - and should go to 7000rpm before looking like touching. I've seen a 440 Mopar run 0.035" to 7000rpm in road racing - no problems except no other 440 could keep up!
What about compression? As long as compression did not increase more than a point - no octane requirement change would result.
You can add an entire point in compression (i.e. go from 9.5:1 to 10.5:1) on the same octane by tightening the quench from 0.050" or more - to under 0.040" - FWIW.
Warning: 1) tight quench is the best hp trick - but you must blueprint EACH piston - do not assume all TDC heights are the same - you'll have to shave the highest pistons to match the lowest one, then deck the block and heads to get your desired quench. Its as basic a power trick as boring using a honing plate - but you'd be amazed how many "top" engine builders don't do it.... trust me ALL the top ones do it... even a Hemi (where the rules allow a tight quench) - now there's a challenge - hand finishing a Hemi piston crown to achieve a blueprinted clearance of 0.040" on the Hemi chamber... Ray Barton can do it. On a Viper with wedge heads its a piece of cake.... but
2) check the piston to valve clearances either side of TDC - worst case scenario would be a need for new pistons with deeper valve reliefs - but the power gain is worth it! You'll feel it seat of pants to drive - its that good, and it picks up response at all rpms - one of those rare power adders that has no downside other than cost.... even ecomomy will improve
Don't we all.
the "quench area"
