Dear juli, Originally, we sent you a small sample, but the more I kept thinking about the challenge, the more concerned I got regarding the size of the bottle. So early in the morning, I packed a larger one to ensure that you had enough product for your test. I now have to wait to see if our product graduates and moves onto the Viper
I just want to thank you for allowing me this opportunity.
Art, thank you for your support and I can't wait to see the new ride.
While on the subject of the Spray~N~Wax, I have taken the liberty to provide the results of a test that we did awhile back.
On another forum, we had a “Friendly Debate” that I'd to call it a “draw,” since neither one of the contenders could make a decision about the targeted subject. During that debate, the performance of the so-called Spray Wax came into discussion. This Spray Wax is a product commonly found within many car care lines - not our particular brand - but a spray wax product itself.
With that in my mind, it got me thinking: maybe my contender is right. Maybe spray waxes are nothing more than a “myth.” So I decided to conduct our own test.
Background
We chose a 1965 trunk lid, a lid that we have used since 2005 we had borrowed the trunk lid for the 2005 National Car Show in Atlanta Georgia, the so-called Nopi Nationals, Organization we sponsor during the 2005 racing season. The car was from Florida, but how well the previous owner cared for it is unknown. I know the car was used from 1965 to 1976, and at the end of the car-life, due to a bad engine, it was parked outside.
The trunk lid had its ORIGINAL paint, now faded and dull. The left side had been prepared by us and no wet sanding had ever been done. We did, however, clay it and, using our products along with a Porter Cable machine, got the best shine that we could accomplish with our products. This showed us that, with the proper technique, tools and products that deliver as advertised, your car's surface can remain a long term investment.
Trunk lid out of storage "As is" (you can click on the photos to enlarge them)
The right side had NEVER been touched, aside from a wash with straight plain water. There was no buffing, sanding, detailing, or single product used on the surface. The test carried out was to see if a Spray Wax could make ANY difference if applied all alone. Of course, today’s car finishes are much better since not too many 1965 panels are used for R&D.
The left side was re-touched to bring the shine back to life. This was clearly seen. The right side remained as we found it originally in 2005. I washed both sides with plain water. The left side shows that it had been protected and the wax job's performance was evident. The right side still appeared as old and dull. With the water applied, little to nothing could be seen, other than a dull finish.
After wash and a little TLC to the left side ONLY
Nothing was accomplished by look or feel. Next, I applied a layer of our spray wax, ONLY to the right side and only to the right portion of the lid. I followed the instructions as indicated on the label.
Clearly signs of two different color tones
As a result, you could actually feel the difference. It was much smoother and, if you looked closely, you could see the right section slightly shine - not much, but enough to see the line where the spray wax was applied. After the spray wax was applied with the help of my assistant, we rinsed the lid with water from a small bucket. Again the left side performed as expected; on the right side absolutely no improvement was seen.
Special helper for the REAL test, the water Test,
left Side
Right Side
With the water little to nothing could be seen, nothing more than a dull finish, nothing was accomplish.
End result a complete failure
I was very disappointed. My contender was correct! Maybe we needed to discontinue this product since we could never sell a spray wax that doesn’t perform as we claim. Then it occurred to me that the water from the bucket was not the correct way to go about it. So we move to another location, next to the garden hose. As I placed the lid on the grass I could imagine my contender next to me, smiling with an I-told-you-so look. Again, we rinsed the lid. Still, nothing happened. As I start walking away I could see that on the right side at the very end of the lid edge, the water was running downward. It was a sign of hope.
So I rinsed again and waited 5 minutes. I could see the same results, not exactly what I was expecting, but now I had something to look forward to. I dried the lid and applied another coat of the spray wax. After I finished removing the excess, I rinsed it again. The results were fantastic!
Different location with the garden hose, zero progress
Now you could CLEARLY see that we had accomplished our goal: a temporary protection, nothing more, nothing less. The product DID work! It worked as it was intended. Yes, it took two coats, but remember, we are talking about a trunk lid from 1965. The test reconfirmed that the spray wax does provide protection and it is a great temporary solution.
Huge progress been made right in front of our own eyes
The only down side is that I have used the original show lid and can never said again that it is "all original." At the end of the day, we can affirm that Spray Waxes do work. After all, I may have to send some to my contender as a token of gratitude for pushing us to prove our own product claims!
Final Answer, Turbo Wax Spray-N-Wax has deliver.The photos don't lie, The Spray-n- Wax has risen to the occassion
