Removal of old clear bra
Vipuronr
Yes, I know this has been discussed before, but a search didn't show anything.
So, I'm going to ask again......
I bought my '98 RT/10 last May and it was a Florida car its whole life. Seems it has clear bra across the front of the hood and is lifting a little at the corners. I have tried the recommended trick of using a hair dryer to try to smooth out those spots but it doesn't work.
I would like to remove it, but am uncomfortable about possibly ruining or lifting some of the paint. I am also considering applying stripes, which requires that the clear bra be removed.
Anyone can offer suggestions, help?
Thanks very much.
Peter
PaViper
If the paint is original, or had been cured for a coulpe of years before the clear bra was applied, you should be fine
Vipuronr
Thanks for the feedback. Unfortunately, I am the second owner and do not have answers for those questions. I do not think the car was repainted and neither does Chuck, but you never know. I would hate to find out differently once I start to remove it.... could be real bummer. It is the reason I have not tried to do it as yet.
Thanks.
Peter
29OUTLAW
Solomons Island, Md.
I removed some from my side sills after having it there for 2 years. Did not pull any paint but you'll need some high-powered adhesive remover to remove the adhesive that's left behind. I used denatured alcohol solvent.
PaViper
If you get an edge up and use a heat gun to soften the adhesive, it may come off easier than you think
FirecatF7
