obaa996
Hi all,
So in another thread, I was trying to remove my front fascia to get to the overflow tank (currently stuck trying to remove stripped s*c*r*e*w under headlight). So while I was at it, I flushed the cooling system. Long story short, I found out the radiator is weeping, and needs to be replaced.
The radiator is a Ron Davis aluminum radiator. Based on my experience with it, I do not intend to get another one. I found that the OEM part is discontinued, so what (copper/brass) alternatives are left? It seems I can either try to find a used one and have it rebuilt before using it, or get one of the "x2" replacements. Are there any other choices available?
Thanks,
Mike
Thanks,
Mike
