Ring gear bolts
01ACR/VIPER
ORLANDO
Can anyone tell me what size they are?A machine shop is telling me they could be either 3/8 or 7/16.3/8 sounds like it to me.:dunno:
Joseph Dell
Atlanta, GA 30338
it can actually be either. depends not only on the year, but what you happen to get in your diff. Sorry i can't be more precise than that! best way to check: open it up and remove one.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Can anyone tell me what size they are?A machine shop is telling me they could be either 3/8 or 7/16. 3/8 sounds like it to me.
Yes, I can tell you. Especially if you plan a gear swap thru Partsrack!
Pending that, you would NOT likley have 3/8 as postulated......THE YEAR MATTERS.
IF you have an 01 ACR, and IF - IF - IF you have the OE diff, and IF IF IF you have OE gears, you would have OE 7/16.
And IF IF IF you order an upgrade thru PartsRack, we'll be sure you get THE RIGHT STUFF
Jack B
NE Ohio
If you have 3/8" bolts, you can have them retapped to 7/16". You also want them drilled/wired, the bolts backing out is a known problem.
Raymond
