Roe "blower only" 9.68 @ 143.5 mph
1TONY1
Dalton Ga. (Chatt. Tn.)
Roe \"blower only\" 9.68 @ 143.5 mph
I did run the nitrous with the street tires and went a 10.41 @ 149.77
BIG thanks to Greg Good for the cylinder heads and his selection on the very streetable camshaft.
ROGUE
SoCal
Re: Roe \"blower only\" 9.68 @ 143.5 mph
Was this with the 6spd... or "other" tranny in it?
Whats the word on the rest of the other events of the day.
1TONY1
Six speed.
Rick SRT10 went 10.40 on street tires in his DLM SRT monster.
The big power turbo cars from UGR rolled into town late today....will be at the track tomorrow.
2MANYTOYS
North Carolina
Great run Tony. Was that on slicks? Sounds like those heads are working well. :2tu:
jwbond
congrats! How many lbs are you running?
Can we see some more info on the car?
Daddy Long Stroke
Very nice Tony! It would be awesome if you could give the full details of your setup. 143 MPH is flat out moving!
Was this on Pump Gas, or Race Gas?
Shelby3
liu;g
That car has to be making high 700's at the rear to hit that number. Great run.
1TONY1
Greg Good heads and Gregs camshaft selection were the major changes besides durability changes......very, very streetable cam, maybe more streetable than a 708 cam. 10lb upper pulley with David Weaver lower pulley.
Three weeks ago I pulled the motor for a last minute rebuild (yes, I have worked my *** off these three weeks) Ended up boring it to clean up the cylinders....that got 10ci" and since we were doing rods I got another 3ci" from the stroke. So now the ci" is 500.7 or .8
I also put my AEM back on and went to Florida with 20 miles of driving on Tuesday and zero dyno time. I spent two hours Saturday morning driving and making a few 2nd gear pulls to get the tune close. It still needs start up and drivability tuning but the full throttle tune can't be far off.
Big thanks to Greg Good for the heads and cam and tech support, Proline Racing Engines that did the machine work asap, Kevin UGR for some engine parts I needed asap, David Weaver for the pulley, UtahViper for the support, Mike Robbins of Ringgold Chrysler for hauling my car down to Florida. Thanks to Sean Roe for a reasonably priced s/c for us low dollar folks.
Today I also sprayed my 150 shot and went a 9.28 @ 151mph 1/8 mile: 6.02 @ 119 :headbang:
Tires are ET Streets.
Fuel was racing gas, I can run pump fuel with this same tune with the W/M ..... but when I am going to be beating on the car over and over the good fuel is a nice safety feature to have. Street driving and the occasional blast this tume will be safe with 93 octane. That is based on an even more aggressive tune that I was running with the vec2 and pump gas on the street and race gas at the track or dyno for safety.
A little know fact....this summer I was playing around with a powerglide in my car. While it never ran quicker than the six speed it was about as quick and would do it time after time consistantly. With this new power, I look forward to trying it again. I have it worked out so I can change from the stick to auto in about 3 hours.
Daddy Long Stroke
Nice.
I have spoken with my Maharaji, and he says Inner happiness for you can only be found by an 8 second timeslip. :D
Daddy Long Stroke
Thanks for the good info!
Last questions: Whats your compression ratio now, and total PSI with the 10 psi upper and David Weaver lower pulley?
Houston, Texas, USA
Tony, a "BIG THANKS" to you for all the hard work you put into the car! You wrenched the car, tuned, and drove it. :2tu: Not many guys have your skills.
I'll take a little bit of credit, maybe 5%. :)
pdmracing
Atlanta Ga
That is SICK! :headbang:
1TONY1
Around 8.8:1 on the compression. The boost should be at 12psi by the pulley sizes, the gauge shows 12 to 12.5
JohnnyBravo
Overland Park, KS
Tony,
Congratulations on an incredible pass. I knew it was just a matter of time before a Roe "blower only" car made it in the 9's.
My plan is to join you in that 9 second club shortly. Greg is working on a set of heads for me as we speak. :)
Nice work, Tony!
99 R/T 10
Enterprise, AL USA
Excellent run Tony :2tu: , but now you have to change your signature! ;)
ViperJoe
Virginia
Tony, that's insane......congrats, and keep the greasy side down!
