-FROG-
From all the research I have been doing with installing my Paxton Supercharger, I am discovering that the harmonic balancer on these cars are not "keyed" and they "can" spin loose. I also come from the world of "Fox Body Mustang 5.0's and we always replaced the balancers because the stock ones fall apart. The stock Viper balancer looks the same as the 5.0's.... ugggg... So with all of the money and time invested in the car, I decided it would be best to spend another $400+ on an ATI balancer. Well, that means I had to pull off my stock one that I already "pinned" with the Roe Crankshaft pin kit. So after pulling it off, I was able to see how everything "seats".
To my discover upon removing the balancer last night, the pin kit looks like is really "keys" the crank well. These pins are rated at about 7,000 lbs of shear force. There are pins that also do come with the Paxton blower kits but my research has shown me that those pins are small and shear off, so consider tossing that pin kit in the trash if you have it and go with the ROE kit.
The ROE kit comes with a LARGE heavy duty guide plate that bolts to the balancer so you don't make any errors in drilling out the crank. The kit is about $80 or so... and recommended for any supercharged car but also many folks recommend them on stock applications because people have actually lost their harmonic balancer in stock cars and it can and will cause damage, even damaging the crank which is a very expensive fix.
So, I hope not to scare anyone with this thread but from all of the research, I decided to put what I have found together for future "searches" on this topic and to help folks prevent damage to their cars.
To remove the crank bolt, put on the E-Brake, put the car in 1st gear and have someone get in the car and hold the brake. Use a cheater bar or torque bar to unscrew the bolt. When installing the bolt, do the same thing. The bolt should be torqued to 250 or 300 ft lbs, depending on your year. Also, use the Red loctite on the threads... that's what everyone is doing.
Things I have found:
1) The Harmonic Balancer is NOT keyed. It is simply "pressed" on from the factory. This is a NO-NO Dodge!!! MORONS....
2) The large Crank bolt is threaded normally, not "reverse threaded". This is also a problem, because from the spinning motion of the engine, it can assist in "loosening" the bolt and then your balancer works it's way off.
3) If your balance works it's way off, you can damage the crank, but it is a bit unlikely because the crank is so darn hard and strong. It is likely that you will damage the front seal and start to leak oil.
4) IF YOU HAVE AN OIL LEAK IN THE FRONT OF THE ENGINE... it may be that the front seal is damaged because the balancer is working it's way off. Check the balancer.
5) If you notice your belt is scuffing or getting tears, check your balancer, because it is rubbing from slippping off.
Here is the kit from ROE - Crankshaft Pin Tool, ALL Vipers & SRT-10 Ram Trucks
The crank pin was not that hard to install, but I did also have many components removed from the front of the engine so it made it easier. Many people use an "angle drill" but screw that... that would take me forever and I am really impatient when it comes to stuff like that. To make it easier, I removed the fan and also unbolted the front "anti sway bar" and let the bar hang down. That allowed me to get my drill in there at an angle with little problem. I did go through (4) 1/4 bits though because I was pushing too hard and dulled the bits, so one may consider buying a few backup bits.
More pics and info on my Supercharger project for any other useful info - http://forums.viperclub.org/threads/648694-FROG-s-Viper-GTS-Paxton-Supercharger-project-pics.
Here is a little trick of how I spun the crank to get to the other hole to drill:
Pics after drilling the holes:
Pins were tapped in with a hammer. Had to slightly grind off a little of one of the pins to make it flush
Here are the pictures of how the pin kit really "keys" the crank well.
