Tri-Y headers have been around for a long time.
They were used on small blocks and less on big blocks.
The pitch was the same then as it is now - tri-y had smaller tubes and gave the benefit of increasing low end power - a good thing for the small block.
The merge collector exhausts used larger tubes and had higher flow rates. Result was more power at the top end with a lot of air moving but a bit less power in the mid range than a smaller tube tri-y.
You might conclude that for stock Viper with those small block holes that a tri-y has a benefit in the mid over a merge. But that the merge will flow more air at the high rpm use or forced air conditions.
