My experience is purely anecdotal, others may vary. I do not think the design is bad, though, and cannot vouch for installation by others, one way or another. I do wonder if an installer that made (or may have made, as once the valve is dropped I doubt you can accurately check to see if the rocker was lashed properly) an error would say "yes, I think I made a mistake and will purchase and install a new engine for you."
I am not sure what "severe usage" means. If you are going over 6000 rpm with great frequency, then I agree, go with shaft rockers.
I will also say that a used set of Crowers I bought that had been "installed correctly but did not work" had been clearly installed incorrectly. Every rocker had been driven down onto every stud and was galled.
I guess I am surprised at the Crower problems people have faced, as I can break an anvil and Crowers are one think I have NOT had problems with. Also, I have yet to hear from anyone that personally installed the rockers who had problems, so there is a bit of a hearsay issue in my mind.
No flames intended, as the shaft pieces are clearly the best.
