Screw in oil pan? ***?
Nitro187
Oakville, Ontario
Changed my oil, and found this on the magnet on the bolt of my oil pan... where could this be from? Doesn't look like anything that should be INSIDE the oil pan....
Re: Screw in oil pan?
Note....... I altered your subject line to achieve the same question
One of your drain pan or the windage tray screws has fallen out...frequent issue... use loctite when/if you re-install pan. Im sure that is a drain-pan screw. A screen above the pickup prevents ingestion of large bits...it can happen again.
tractor1996
