prevnine11ownr
My buddy just put a 100 shot NX on his 97 Vette.. He has exhaust and a few bolt on mods.. I run high 11's? Waddya think? We would def go from a roll? Thanks!
How much torque did he plant...hp is just trophy...torque is what shreds tires and wins races...
That should be a 530rwhp, 3250 lb car. Something is seriously wrong if he's only running 11.7, especially with an auto. That should be a 10 second car.
No, what I mean is a standard head/cam/bolt-on vette is putting down 430 - 450 rwhp. Add a 100 shot on top of that and it's pushing 530 at the wheels. Sticky tires and a converter will put a head/cam/100nx vette into the 10s.You'd think...but vettes are grossly underpowered...
So said Snake Bitten
You'll smoke him...bad...He might have been planting 300 rwhp with stock...maybe...
Roast him...try and start in 2nd gear...around 55 mph...
So said Lee00blacksilverGTS
Listen to the man from MN, he's so right! But listen well, 50-60 mph roll, second gear, NOT third.
but i will tell u this: once u got it down its all about the bottle pressure. if he has everything tuned right for 1067 lbs. of pressure (97 degrees of bottle temp.) then it will be very close. could go either way in that case. it will all come down to the launch. but if he hits the button out of the hole his skinnier tires will smoke harder than yours and u will have him with a hole shot. good luck man and let me know how it goes.
i get my bottle up 2 temp by pre heating them with the air heater in my truck. then i maintain that temp with a nos bottle heater kit wired to my race ride, i take the thermostats out of the heater kit and toss em in the garbage. i hard wire the heater so either it is on our off, this way i get the bottle as hot as i want it and regulate the flutuations in temp myself. the only problem with this is that if u forget 2 check your temp and turn it off u could over heat your bottle and blow your ride sky high. ay chihuahua!!! so don't be drinkin and drivin. lol!
