side splitters
SNKEBIT
western wisc.
How does one attach the side splitters to the bottom of the sills???
What are they made out of???? I want to put some on my car and could use a little info before I mess something up!!! LOL
Thanks in advance, Mitch :usa:
Nadine UK GTS
Bath, Somerset, UK
I had some made in carbon fiber, clamped them to the sill, while I drilled small 5mm holes to bolt them up. Used stainless steel button-head 15 mm long bolts and lock nuts (bolt head splitter side) and large stainless washers either side. Used about 15 bolts per side.
SNKEBIT
SNKEBIT
western wisc.
Thanks Nadine!!!! You Rock!!!!!!!! :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
How far from the sill do they stick out????? How far did you put yours????
Thanks, Mitch :2tu:
Nadine UK GTS
Bath, Somerset, UK
This pic shows the position of where to drill to fix the splitter on, this is copied exactly as Dodge did with the GT2 factory splitters except they used rivits.
