What I'd really like to do is reduce the gap between 5th and 6th gear. I'm reluctant to change the diff ratio just to do this since that will also lower 1st gear which I kind of like the way it is. Lowering the diff ratio will close up all the gears a bit which I suppose is a good thing but will still leave that massive 5/6 gap. 1st to 4th ratios are quite well chosen with 4th to 5th acceptable but I rarely use 6th on the road and on a track it must be useless even with a lower diff. Which brings me back to my point, has anyone tried that Giwasa 6th gear. BTW I havn't been able to get thru to their site today.
Rascal, yes I hope to be at the 200mph event so if I don't see you sooner see you there!
